Combing
Combing
Post by LePaul » February 18th, 2017, 9:13 am
Any ideas how to make this a bit cleaner in S3D?
Re: Combing
Post by Neotko » February 18th, 2017, 9:32 am
Horizontal expansion -0.10 that will make the hole text look better, you need to make the texts assuming that pla expands 0.10 otherwise it won't look ok. Also, that's the hardest thing to make look good.
Also, deactivate 'Only retract while crossing open spaces'. But for that you need a feeder that doesn't chew material.
Re: Combing
Post by LePaul » February 18th, 2017, 11:21 am
Thanks. Which tab Ian that under?
Re: Combing
Post by LePaul » February 18th, 2017, 5:30 pm
Home from work....in front of S3D...found the settings! Let's try again
Return to “Simplify 3D”
