New version is out!
New version is out!
Post by LePaul » June 10th, 2016, 10:50 am
https://www.simplify3d.com/software/release-notes/
Version 3.1.0
Added support for XYZprinting da Vinci 1.1 Plus, da Vinci 1.0 Pro, and da Vinci Jr. 1.0
Updated support for latest FlashForge Dreamer firmware and new FlashForge Finder 3D printer
New support for Bits-from-Bytes (BFB) file format including automatic flowrate control
New file format export options to streamline the creation and management of multiple file formats
Added support for line numbering and checksums during USB printing for real-time error checking and improved reliability
Numerous enhancements to USB printing for da Vinci machines including real-time preview tracking and progress reporting
Added support for Wi-Fi printing to da Vinci 1.1 Plus and da Vinci 1.0 Pro
Multiple process dialog now uses the previously selected processes as the default selection
More intuitive file extension prompts when exporting toolpaths into different file formats
New firmware configuration option for using software-based flow control
Cross-section tool now allows easy selection and editing of internal model features including interior support structures
Customized profiles created using the Configuration Assistant will now be compatible with the Dual Extrusion Wizard
Improved pre-heating sequence for multiple extruders
Improved retract-while-wiping performance for complex shapes and fill patterns
Improved retractions when creating multiple ooze shields and prime pillars
Continued improvements to the slicing engine for automatically handling models with slight defects or mesh errors
Improved filtering for small movements during toolpath generation
Improved support for latest Smoothieware firmware and USB communication protocols
Post-processing scripts can now contain commas
Post-processing comments in the gcode header will now be maintained to avoid extra line breaks or invalid commands
Improved warnings for firmware or machine settings that will be overriden by your process settings
New warning to prevent closing the software when an active print is running
New licensing improvements for easier management of software installations
Added over 30 new pre-configured profiles including the 3D Systems CubePro, BCN3D Sigma, bq Prusa i3 Hephestos 2, Cocoon Create 3D Printer, CTC Bizer Dual, E3D BigBox, LulzBot TAZ 6, MendelMax 3.0 Dual, Monoprice Maker Select, PowerSpec Ultra, Raise3D N2, re:3D Gigabot 2 XL and Gigabot 3 XL, Renkforce RF2000, Kossel Pro, Robo3D R1+, Turnigy Fabrikator and Fabrikator Mini, Ultimaker 2+, Ultimaker 2 Extended+, DeltaWASP 20×40, and DeltaWASP 40×70
Return to “Simplify 3D”
