Code: Select all
"acceleration_enabled": false,
"acceleration_infill": 3000,
"acceleration_layer_0": 3000,
"acceleration_prime_tower": 3000,
"acceleration_print": 3000,
"acceleration_print_layer_0": 3000,
"acceleration_skirt_brim": 3000,
"acceleration_support": 3000,
"acceleration_support_infill": 3000,
"acceleration_support_interface": 3000,
"acceleration_topbottom": 3000,
"acceleration_travel": 5000,
"acceleration_travel_layer_0": 5000.0,
"acceleration_wall": 3000,
"acceleration_wall_0": 3000,
"acceleration_wall_x": 3000,
"adhesion_extruder_nr": "0",
"adhesion_type": "brim",
"alternate_extra_perimeter": false,
"blackmagic": 0,
"bottom_layers": 8,
"bottom_thickness": 0.8,
"brim_line_count": 20,
"brim_outside_only": true,
"brim_width": 8.0,
"coasting_enable": false,
"coasting_min_volume": 0.8,
"coasting_speed": 90,
"coasting_volume": 0.064,
"conical_overhang_angle": 50,
"conical_overhang_enabled": false,
"cool_fan_enabled": true,
"cool_fan_full_at_height": 0.3,
"cool_fan_full_layer": 2,
"cool_fan_speed": 100.0,
"cool_fan_speed_max": 100.0,
"cool_fan_speed_min": 100.0,
"cool_lift_head": false,
"cool_min_layer_time": 5,
"cool_min_layer_time_fan_speed_max": 10,
"cool_min_speed": 10,
"cooling": 0,
"draft_shield_dist": 10,
"draft_shield_enabled": false,
"draft_shield_height": 10,
"draft_shield_height_limitation": "full",
"dual": 0,
"experimental": 0,
"extruder_prime_pos_abs": false,
"extruder_prime_pos_x": 0,
"extruder_prime_pos_y": 0,
"extruder_prime_pos_z": 0,
"gantry_height": 55,
"gradual_infill_step_height": 5.0,
"gradual_infill_steps": 0,
"infill": 0,
"infill_before_walls": true,
"infill_line_distance": 4.0,
"infill_line_width": 0.4,
"infill_mesh": false,
"infill_mesh_order": 0,
"infill_overlap": 10,
"infill_overlap_mm": 0.04,
"infill_pattern": "grid",
"infill_sparse_density": 20,
"infill_sparse_thickness": 0.1,
"infill_wipe_dist": 0.1,
"jerk_enabled": false,
"jerk_infill": 20,
"jerk_layer_0": 20,
"jerk_prime_tower": 20,
"jerk_print": 20,
"jerk_print_layer_0": 20,
"jerk_skirt_brim": 20,
"jerk_support": 20,
"jerk_support_infill": 20,
"jerk_support_interface": 20,
"jerk_topbottom": 20,
"jerk_travel": 30,
"jerk_travel_layer_0": 30.0,
"jerk_wall": 20,
"jerk_wall_0": 20,
"jerk_wall_x": 20,
"layer_0_z_overlap": 0.15,
"layer_height": 0.1,
"layer_height_0": 0.3,
"line_width": 0.4,
"machine_acceleration": 4000,
"machine_center_is_zero": false,
"machine_depth": 205,
"machine_extruder_count": 1,
"machine_gcode_flavor": "RepRap (Marlin/Sprinter)",
"machine_heat_zone_length": 16,
"machine_heated_bed": true,
"machine_height": 200,
"machine_max_acceleration_e": 10000,
"machine_max_acceleration_x": 9000,
"machine_max_acceleration_y": 9000,
"machine_max_acceleration_z": 100,
"machine_max_feedrate_e": 45,
"machine_max_feedrate_x": 500,
"machine_max_feedrate_y": 500,
"machine_max_feedrate_z": 30,
"machine_max_jerk_e": 5.0,
"machine_max_jerk_xy": 20.0,
"machine_max_jerk_z": 0.4,
"machine_min_cool_heat_time_window": 50.0,
"machine_minimum_feedrate": 0.0,
"machine_name": "Ultimaker Original+",
"machine_nozzle_cool_down_speed": 2,
"machine_nozzle_expansion_angle": 45,
"machine_nozzle_head_distance": 3,
"machine_nozzle_heat_up_speed": 2,
"machine_nozzle_size": 0.4,
"machine_nozzle_tip_outer_diameter": 1,
"machine_settings": 0,
"machine_show_variants": false,
"machine_use_extruder_offset_to_offset_coords": true,
"machine_width": 205,
"magic_fuzzy_skin_enabled": false,
"magic_fuzzy_skin_point_density": 1.25,
"magic_fuzzy_skin_point_dist": 0.8,
"magic_fuzzy_skin_thickness": 0.3,
"magic_mesh_surface_mode": "normal",
"magic_spiralize": false,
"material": 0,
"material_bed_temp_prepend": true,
"material_bed_temp_wait": true,
"material_bed_temperature": 60,
"material_diameter": 2.85,
"material_extrusion_cool_down_speed": 0.5,
"material_flow": 100,
"material_flow_dependent_temperature": false,
"material_flow_temp_graph": "[[3.5,200],[7.0,240]]",
"material_guid": "",
"material_print_temp_prepend": true,
"material_print_temp_wait": true,
"material_print_temperature": 200,
"material_standby_temperature": 175,
"max_feedrate_z_override": 0,
"meshfix": 0,
"meshfix_extensive_stitching": false,
"meshfix_keep_open_polygons": false,
"meshfix_union_all": true,
"meshfix_union_all_remove_holes": false,
"multiple_mesh_overlap": 0.15,
"ooze_shield_angle": 60,
"ooze_shield_dist": 2,
"ooze_shield_enabled": false,
"outer_inset_first": false,
"platform_adhesion": 0,
"prime_tower_enable": false,
"prime_tower_flow": 100,
"prime_tower_line_width": 0.4,
"prime_tower_position_x": 200,
"prime_tower_position_y": 200,
"prime_tower_size": 0,
"prime_tower_wipe_enabled": true,
"print_sequence": "all_at_once",
"raft_acceleration": 3000,
"raft_airgap": 0.3,
"raft_base_acceleration": 3000,
"raft_base_fan_speed": 0,
"raft_base_jerk": 20,
"raft_base_line_spacing": 1.6,
"raft_base_line_width": 0.8,
"raft_base_speed": 22.5,
"raft_base_thickness": 0.36,
"raft_fan_speed": 0,
"raft_interface_acceleration": 3000,
"raft_interface_fan_speed": 0,
"raft_interface_jerk": 20,
"raft_interface_line_spacing": 1.0,
"raft_interface_line_width": 0.8,
"raft_interface_speed": 22.5,
"raft_interface_thickness": 0.15000000000000002,
"raft_jerk": 20,
"raft_margin": 15,
"raft_speed": 30.0,
"raft_surface_acceleration": 3000,
"raft_surface_fan_speed": 0,
"raft_surface_jerk": 20,
"raft_surface_layers": 2,
"raft_surface_line_spacing": 0.4,
"raft_surface_line_width": 0.4,
"raft_surface_speed": 30.0,
"raft_surface_thickness": 0.1,
"resolution": 0,
"retraction_amount": 6.5,
"retraction_combing": "all",
"retraction_count_max": 90,
"retraction_enable": true,
"retraction_extra_prime_amount": 0,
"retraction_extrusion_window": 6.5,
"retraction_hop": 1,
"retraction_hop_after_extruder_switch": true,
"retraction_hop_enabled": false,
"retraction_hop_only_when_collides": false,
"retraction_min_travel": 0.8,
"retraction_prime_speed": 25,
"retraction_retract_speed": 25,
"retraction_speed": 25,
"shell": 0,
"skin_alternate_rotation": false,
"skin_line_width": 0.4,
"skin_no_small_gaps_heuristic": true,
"skin_outline_count": 0,
"skin_overlap": 5,
"skin_overlap_mm": 0.02,
"skirt_brim_line_width": 0.4,
"skirt_brim_minimal_length": 250,
"skirt_brim_speed": 30,
"skirt_gap": 3,
"skirt_line_count": 1,
"speed": 0,
"speed_equalize_flow_enabled": false,
"speed_equalize_flow_max": 150,
"speed_infill": 60,
"speed_layer_0": 30,
"speed_prime_tower": 60,
"speed_print": 60,
"speed_print_layer_0": 30,
"speed_slowdown_layers": 2.0,
"speed_support": 60,
"speed_support_infill": 60,
"speed_support_interface": 40.0,
"speed_topbottom": 30.0,
"speed_travel": 120,
"speed_travel_layer_0": 60.0,
"speed_wall": 30.0,
"speed_wall_0": 30.0,
"speed_wall_x": 60.0,
"support": 0,
"support_angle": 50,
"support_bottom_distance": 0.1,
"support_bottom_height": 1,
"support_bottom_stair_step_height": 0.3,
"support_conical_angle": 30,
"support_conical_enabled": false,
"support_conical_min_width": 5.0,
"support_connect_zigzags": true,
"support_enable": false,
"support_extruder_nr": "0",
"support_extruder_nr_layer_0": "0",
"support_infill_extruder_nr": "0",
"support_infill_rate": 15,
"support_interface_density": 100,
"support_interface_enable": false,
"support_interface_extruder_nr": "0",
"support_interface_height": 1,
"support_interface_line_distance": 0.4,
"support_interface_line_width": 0.4,
"support_interface_pattern": "concentric",
"support_interface_skip_height": 0.3,
"support_join_distance": 2.0,
"support_line_distance": 2.6666666666666665,
"support_line_width": 0.4,
"support_minimal_diameter": 3.0,
"support_offset": 0.2,
"support_pattern": "zigzag",
"support_roof_height": 1,
"support_top_distance": 0.1,
"support_tower_diameter": 3.0,
"support_tower_roof_angle": 65,
"support_type": "everywhere",
"support_use_towers": true,
"support_xy_distance": 0.7,
"support_xy_distance_overhang": 0.2,
"support_xy_overrides_z": "z_overrides_xy",
"support_z_distance": 0.1,
"switch_extruder_prime_speed": 20,
"switch_extruder_retraction_amount": 16,
"switch_extruder_retraction_speed": 20,
"switch_extruder_retraction_speeds": 20,
"top_bottom_pattern": "lines",
"top_bottom_thickness": 0.8,
"top_layers": 8,
"top_thickness": 0.8,
"travel": 0,
"travel_avoid_distance": 0.625,
"travel_avoid_other_parts": true,
"travel_compensate_overlapping_walls_0_enabled": true,
"travel_compensate_overlapping_walls_enabled": true,
"travel_compensate_overlapping_walls_x_enabled": true,
"wall_0_inset": 0,
"wall_line_count": 2,
"wall_line_width": 0.4,
"wall_line_width_0": 0.4,
"wall_line_width_x": 0.4,
"wall_thickness": 0.8,
"wireframe_bottom_delay": 0,
"wireframe_drag_along": 0.6,
"wireframe_enabled": false,
"wireframe_fall_down": 0.5,
"wireframe_flat_delay": 0.1,
"wireframe_flow": 100,
"wireframe_flow_connection": 100,
"wireframe_flow_flat": 100,
"wireframe_height": 3,
"wireframe_nozzle_clearance": 1,
"wireframe_printspeed": 5,
"wireframe_printspeed_bottom": 5,
"wireframe_printspeed_down": 5,
"wireframe_printspeed_flat": 5,
"wireframe_printspeed_up": 5,
"wireframe_roof_drag_along": 0.8,
"wireframe_roof_fall_down": 2,
"wireframe_roof_inset": 3,
"wireframe_roof_outer_delay": 0.2,
"wireframe_straight_before_down": 20,
"wireframe_strategy": "compensate",
"wireframe_top_delay": 0,
"wireframe_top_jump": 0.6,
"wireframe_up_half_speed": 0.3,
"xy_offset": 0,
"z_seam_type": "shortest"
