SketchUp with Cura 2.3.1
Jockel1957
3D Printer(s): Anet A8
Post by Jockel1957 » December 4th, 2016, 1:27 pm
Hi,
First I have to say that I have been dealing with 3d printing (Anet A8) and thus with the software (SketchUup 2017 and Cura 2.3.1) only for 2 weeks, so completely newcomer in this area.
I have now determined that all prints of a certain size after the conversion of stl into the gcode over Cura are printed too small. My first prints were all small parts, I did not notice, they were all measured. So I'm assuming that I've done something wrong when saving to the gcode on the memory card. But then all the parts would have to have a wrong measure.
Best regards
Joachim
Best regards
Joachim
Re: SketchUp with Cura 2.3.1
Post by Amedee » December 4th, 2016, 1:39 pm
Hi!
Maybe the first things to check are the Cura preferences. There is an evil one called 'Scale large model' which is checked by default and that one will almost silently resize your models...
Cura Prefs
Phil.
Post by Izzy » December 4th, 2016, 1:50 pm
Welcome Jockel, hope you get your problem solved, Where are you located?
Izzy.
Post by LePaul » December 4th, 2016, 1:52 pm
Yeah many of us got dinged by that auto scaling. I thought they changed the pop up to alert you it had been scaled down to stay on the screen longer?
Either way....it should be OFF by default, in my opinion!
Jockel1957
Post by Jockel1957 » December 4th, 2016, 3:44 pm
HI;
@Phil: these are the settings of my Cura
when I delete the 3 marks at "opening files", I can`t continue working (see last picture)
@Izzy: I come from Germany, live in Hamburg
@LePaul: do you mean the window at the bottom of the image 2 and 4?
Best regards
Joachim
Post by Izzy » December 4th, 2016, 3:50 pm
Hi Joachim,
Paul will confirm, but yes it has rescaled your part,
Image 2 it has shrunk to fit, image 4 it is too big for the print area.
It may be that your STL output has picked up a large surface or plain if it is a part that should fit within a 220x220 box.
Izzy.
Post by LePaul » December 4th, 2016, 4:08 pm
Be aware that in many cases the part will fit...when the orientation has been adjusted (rotated, moved vertically, etc) But, for some reason, Cura leaves that setting on by default, so it shrinks it to fit the load view....which sucks. I had several parts shrunk down a few percent and I didn't notice it until I tried aligning different portions of the assembly. They owe me some filament!!! :)
Uncheck that option Izzy mentions and move the part around to fit as needed.
Jockel1957
Post by Jockel1957 » December 4th, 2016, 6:40 pm
Hi,
I have found the mistake by chance, I always saved also the bottom of the box, and of course it was always too big for Cura. So before saving in SketchUp, you must delete the floor, then everything works.
many thanks for your help
Best regards
Joachim
Post by Amedee » December 5th, 2016, 2:01 am
If my memory serves well, there is also an option in sketchup to save ´selected objects' instead of ´all' .
That way you don't have to delete anything.
On a side note, I used sketchup quite a lot in the past, but I eventually stepped away from it because it is too easy to make non-manifold models which won't be printable...
Phil.
Post by LePaul » December 5th, 2016, 9:27 am
What's your preferred program now?
Post by Amedee » December 5th, 2016, 9:41 am
It depends on what you are doing...
For what I do, I ended up using Fusion 360. It is free for students and hobbyists.
I like this chart -- it is not very recent, but it gives some overview...
Phil.
Post by LePaul » December 5th, 2016, 10:03 am
That's great!
nallath
3D Printer(s): Ultimaker
Post by nallath » December 6th, 2016, 4:43 am
LePaul wrote:Yeah many of us got dinged by that auto scaling. I thought they changed the pop up to alert you it had been scaled down to stay on the screen longer?
Yea, It should also no longer scale to 99%. It should only start scaling if it's way to big / small
LePaul wrote: Either way....it should be OFF by default, in my opinion!
This validates my point that most people here are engineer minded. Most artists tend to want this, as they want something that just works (regardless of it being "correct").
Post by LePaul » December 6th, 2016, 9:50 am
I guess I like the simple way old Cura did it. If it wasn't yellow, it didn't fit.
You went into scale mode if it was huge and adjusted accordingly.
nallath
Post by nallath » December 6th, 2016, 11:11 am
Uh. Old cura also scaled ;)
Return to “Cura”
Users browsing this forum: No registered users and 5 guests
