Cura 2.1 open beta
Re: Cura 2.1 open beta
Does anybody know we're the option to print one at a time or all a once is?
- martin-bienz
Izzy, yes, its in specialmodes and its called print sequence.
Cheers Martin, I wanted to toggle it to see if i could un-stick Cura, no joy
- martin-bienz
Thats sad... can you do me favor, are you on windows? If yes, close cura, go to your local appdata folder (start, run, %localapdata% and enter), rename the cura folder to cura.old or similar. Then start cura again. It should start with default settings. Try again...
Couldn't find the relevant folder,
I uninstalled Cura and re installed it for a 3rd time, this time it seems to be working
It failed again, but I think it's the virus protector.
I use Pandasoft, it asked permissions etc when installing but then quarantined a file when it ran again, I think I have now allowed the necessary files with permissions.
I will let you know if all ok over the next few days.
Cheers, Izzy
Cheers, Izzy
I hadn't thought of that...I run TrendMicro since Symantec was a nightmare for years, hogging up resources
- drayson
thanky for the hint. Tried to test switch from "all at once" to "one at a time" and the strange thing is, the print area height is reduced drastically (blue box)...martin-bienz wrote:Izzy, yes, its in specialmodes and its called print sequence.
Has anybody else seen this?
- martin-bienz
Youp, exactly what happend to me. My "default" is to print one object after the other, so coming from 15.x I changed that setting in 2.x also. If you do that you get that blue box (basically that was there in old cura also, but it just told you something like: "Object is to high, switching to print all at once"). Now that is a pain in the but if you only print one object... right .drayson wrote: thanky for the hint. Tried to test switch from "all at once" to "one at a time" and the strange thing is, the print area height is reduced drastically (blue box)...
