print only shell, not walls
cla68
3D Printer(s): MOOZ_2, M3D
Post by cla68 »
Hello, it's first time I post in this forum. I use 3d printer since three years, just for hobbies. I have a M3D and then I got a Mooz2. M3D has its own slicing software integrated. I have a simple model (attached) which I successfully printed with M3D. Now I try using Cura (3.2.1). Here attached settings. For same model printed I get only outer shell, no walls, no base thickess. May I get a help? thanks.
piede lampada rev2.1 fixed.stl
(149.3 KiB) Downloaded 250 times
Re: print only shell, not walls
I checked your model on my system (same Cura), and the only way to get it to do what you are saying is if I have Spiralize Outer Contour enabled under Special Modes. Check that setting.
cla68
Post by cla68 »
Yes, the option 'Spiralize Outer Contour' is enabled. So, I should disable it and re-try, correct? thanks :-)
Yes shut that off
cla68
Post by cla68 »
It works, thanks!
I do not know Cura in details. One question: in my model posted there is a small hole in vertical, at the mid of a simple cylinder, a sort of glass. The layers printed at the same height of hole are not very good, those printed inside the part. I wonder if I could test some alternative settings which could get rid of such 'faulty' layers.
Here are my Cura settings for 2.6.2 they are importable to 3.2.1
Cura 2.6.2.zip
(2.19 KiB) Downloaded 252 times
cla68
Post by cla68 »
Thanks. I am going to try the version 0.2 mm. Thanks
Return to “Cura”
