In reflection mode may be a dual tilting/lifting print head !?
Re: UM2 print head project
Posted: July 15th, 2016, 8:12 pm
Nice workshop!
Mine has two R2-D2's, a Stormtrooper suit and Dark Knight suit on display lol I should invest in tools as you have
Posted: July 16th, 2016, 3:01 am
Just one think. Would the hotend be able to rotate on a linear bearing? If you get a lm6luu bearing with a shaft and try to rotating it, it gives friction. It might affect the system? Just thinking out loud.
Posted: July 16th, 2016, 4:04 am
by gudo
no problem it exists linear/rotating bearings
Posted: July 16th, 2016, 5:40 am
Maybe with a shorter linear bearing you could fit the bowden just on the middle so the print area remains almost the same. I say this because it seems 19mm long vs the standard 35mm. I wonder if a shorter one affects vibrations.
Posted: July 16th, 2016, 6:19 am
by gudo
you're going to say I have all the answers
In addition to the 19mm linear/rot. bearing of the slider Y , this one is completely integral with the slider X in rotation through 2 flanged bearings
Posted: July 16th, 2016, 6:33 am
Dude that's just amazing! Not only you really know how to 3d design also you can do pretty much anything :O
I'm really amazed!
Posted: July 16th, 2016, 6:49 am
by gudo
Thanks ! you are so kind
I would not want to make false modesty, I only operate all my experience gained during 30 years in the mechanical.
Posted: July 16th, 2016, 2:41 pm
by Izzy
I'm glad my iPad is in a waterproof case, I was drooling on it looking at your workshop
Posted: July 16th, 2016, 4:20 pm
by gudo
Izzy !!! some restraint please !
I am a little ashamed of the chaos in the workshop
Posted: July 16th, 2016, 5:27 pm
Can I leave my problematic Ultimaker Original in your shop and pick it up once you've converted it to something genius?
Posted: July 17th, 2016, 5:46 am
by gudo
Hi LePaul
Why not? I would love to do it !
by cons, very hot! transportation costs
Posted: July 17th, 2016, 11:24 am
Oh true...I can dream
Posted: July 20th, 2016, 1:56 pm
by gudo
Hi to all
I continue my PBI experiences
Today I test for the first time the ABS extrusion with the PBI print head
Benchy served as an example, it was printed with a EasyFil ABS from Form Futura at 252°print temp
ABS material settings of the printer
0.4mm nozzle, 0.1 layers, 50mm/s print speed, 0.8mm wall/top/bottom, 20% infill, 90° bed temp, 3mm retract distance, 10mm brim....
The ABS extrusion is OK, no any problem or friction issue, I had to stop the print 3 times when starting because of the bed adhesion issue, so after solve it, the test went pretty well with a small warping issue, I still lacks printing experience with ABS, to be honest I hate this material !
2 horizontal lines seen on the pics
the first at few mm. upper the bed it's due to a manualy varation print temp setting from 260° to 252°
the second higherit's due to a suddenly small warping on the bed
